Time Before: 0.00800 seconds
Time After: 0.01165 seconds
Time Taken: 0.00365 seconds
Time Before: 0.01175 seconds
Time After: 0.01224 seconds
Time Before: 0.01250 seconds
Time After: 0.01267 seconds
Time Before: 0.01352 seconds
Time After: 0.01616 seconds
Time Taken: 0.00264 seconds
Time Before: 0.01275 seconds
Time After: 0.02033 seconds
Time Taken: 0.00758 seconds
Time Before: 0.02417 seconds
Time After: 0.02459 seconds
Time Before: 0.02587 seconds
Time After: 0.02720 seconds
Time Taken: 0.00133 seconds
Time Before: 0.02353 seconds
Time After: 0.02753 seconds
Time Taken: 0.00401 seconds
Time Before: 0.04445 seconds
Time After: 0.04462 seconds
Time Before: 0.05233 seconds
Time After: 0.05357 seconds
End call of global.php: 0.05593204498291
Time Before: 0.05954 seconds
Time After: 0.05971 seconds
Time Before: 0.06254 seconds
Time After: 0.06404 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=10459'
Time Before: 0.08198 seconds
Time After: 0.08223 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.080925941467285 seconds with 9 queries, spending 0.0083849430084229 doing MySQL queries and 0.072540998458862 doing PHP things.
