Time Before: 0.00307 seconds
Time After: 0.00398 seconds
Time Taken: 0.00091 seconds
Time Before: 0.00406 seconds
Time After: 0.00472 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00501 seconds
Time After: 0.00515 seconds
Time Before: 0.00584 seconds
Time After: 0.00856 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00520 seconds
Time After: 0.01201 seconds
Time Taken: 0.00681 seconds
Time Before: 0.01401 seconds
Time After: 0.01445 seconds
Time Before: 0.01774 seconds
Time After: 0.01893 seconds
Time Before: 0.01323 seconds
Time After: 0.01911 seconds
Time Taken: 0.00588 seconds
Time Before: 0.02577 seconds
Time After: 0.02592 seconds
Time Before: 0.02840 seconds
Time After: 0.02975 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.031386852264404
Time Before: 0.03255 seconds
Time After: 0.03272 seconds
Time Before: 0.03507 seconds
Time After: 0.03653 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=104609', badlocation = 1
WHERE sessionhash = 'cf9a7d249f143a0ae3eb7b561aa7a27f'
Time Before: 0.04952 seconds
Time After: 0.04982 seconds
Page generated in 0.048322916030884 seconds with 9 queries, spending 0.0085799694061279 doing MySQL queries and 0.039742946624756 doing PHP things.
