Time Before: 0.01926 seconds
Time After: 0.02471 seconds
Time Taken: 0.00545 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.02479 seconds
Time After: 0.02520 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.02547 seconds
Time After: 0.02561 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.02655 seconds
Time After: 0.02896 seconds
Time Taken: 0.00241 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.02569 seconds
Time After: 0.03339 seconds
Time Taken: 0.00770 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.04428 seconds
Time After: 0.04472 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.04821 seconds
Time After: 0.05020 seconds
Time Taken: 0.00200 seconds
Memory Before: 2,148.906 KB
Memory After: 2,148.766 KB
Time Before: 0.04351 seconds
Time After: 0.05048 seconds
Time Taken: 0.00698 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.789 KB
Time Before: 0.08934 seconds
Time After: 0.08974 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.11141 seconds
Time After: 0.11281 seconds
Time Taken: 0.00140 seconds
Memory Before: 2,903.656 KB
Memory After: 2,904.250 KB
Time Before: 0.12539 seconds
Time After: 0.12556 seconds
Memory Before: 3,540.422 KB
Memory After: 3,540.852 KB
Time Before: 0.12797 seconds
Time After: 0.12980 seconds
Time Taken: 0.00184 seconds
Memory Before: 3,821.953 KB
Memory After: 3,823.641 KB
UPDATE session SET lastactivity = 1776534798, location = '/forums/private.php?do=newpm&explain=1&u=104619' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.14724 seconds
Time After: 0.14765 seconds
Memory Before: 4,295.914 KB
Memory After: 4,296.141 KB
