Time Before: 0.01297 seconds
Time After: 0.01739 seconds
Time Taken: 0.00442 seconds
Time Before: 0.01749 seconds
Time After: 0.01797 seconds
Time Before: 0.01827 seconds
Time After: 0.01842 seconds
Time Before: 0.01918 seconds
Time After: 0.02192 seconds
Time Taken: 0.00274 seconds
Time Before: 0.01847 seconds
Time After: 0.02590 seconds
Time Taken: 0.00743 seconds
Time Before: 0.03106 seconds
Time After: 0.03143 seconds
Time Before: 0.03414 seconds
Time After: 0.03590 seconds
Time Taken: 0.00177 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03045 seconds
Time After: 0.03613 seconds
Time Taken: 0.00569 seconds
Memory After: 2,261.703 KB
Time Before: 0.06077 seconds
Time After: 0.06092 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06875 seconds
Time After: 0.07104 seconds
Time Taken: 0.00230 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.074153900146484
Time Before: 0.07698 seconds
Time After: 0.07713 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.08008 seconds
Time After: 0.08161 seconds
Time Taken: 0.00154 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=104643'
Time Before: 0.10009 seconds
Time After: 0.10055 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.098927021026611 seconds with 9 queries, spending 0.010103940963745 doing MySQL queries and 0.088823080062866 doing PHP things.
