Time Before: 0.00137 seconds
Time After: 0.00190 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00197 seconds
Time After: 0.00240 seconds
Time Before: 0.00267 seconds
Time After: 0.00281 seconds
Time Before: 0.00371 seconds
Time After: 0.00608 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00287 seconds
Time After: 0.01054 seconds
Time Taken: 0.00768 seconds
Time Before: 0.01254 seconds
Time After: 0.01276 seconds
Time Before: 0.01583 seconds
Time After: 0.01700 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01181 seconds
Time After: 0.01726 seconds
Time Taken: 0.00545 seconds
Time Before: 0.02383 seconds
Time After: 0.02398 seconds
Time Before: 0.02629 seconds
Time After: 0.02753 seconds
Time Before: 0.03128 seconds
Time After: 0.03144 seconds
Time Before: 0.03483 seconds
Time After: 0.03627 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104647', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.05076 seconds
Time After: 0.05108 seconds
