Time Before: 0.00173 seconds
Time After: 0.00232 seconds
Time Taken: 0.00059 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00238 seconds
Time After: 0.00282 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00302 seconds
Time After: 0.00312 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00385 seconds
Time After: 0.00618 seconds
Time Taken: 0.00233 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00317 seconds
Time After: 0.01023 seconds
Time Taken: 0.00705 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01294 seconds
Time After: 0.01320 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01550 seconds
Time After: 0.01670 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.01221 seconds
Time After: 0.01687 seconds
Time Taken: 0.00466 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.02206 seconds
Time After: 0.02218 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.02417 seconds
Time After: 0.02537 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
End call of global.php: 0.027128934860229
Time Before: 0.02838 seconds
Time After: 0.02854 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.03074 seconds
Time After: 0.03218 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=104664'
Time Before: 0.04491 seconds
Time After: 0.04518 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
Page generated in 0.044031858444214 seconds with 9 queries, spending 0.007519006729126 doing MySQL queries and 0.036512851715088 doing PHP things.
