Time Before: 0.00148 seconds
Time After: 0.00195 seconds
Time Before: 0.00202 seconds
Time After: 0.00240 seconds
Time Before: 0.00261 seconds
Time After: 0.00274 seconds
Time Before: 0.00339 seconds
Time After: 0.00610 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00279 seconds
Time After: 0.01090 seconds
Time Taken: 0.00812 seconds
Time Before: 0.01312 seconds
Time After: 0.01377 seconds
Time Taken: 0.00065 seconds
Time Before: 0.01627 seconds
Time After: 0.01757 seconds
Time Before: 0.01208 seconds
Time After: 0.01775 seconds
Time Taken: 0.00567 seconds
Time Before: 0.02326 seconds
Time After: 0.02342 seconds
Time Before: 0.02585 seconds
Time After: 0.02715 seconds
Time Before: 0.03141 seconds
Time After: 0.03162 seconds
Time Before: 0.03423 seconds
Time After: 0.03568 seconds
UPDATE session SET lastactivity = 1789104706, location = '/forums/private.php?do=newpm&explain=1&u=104703', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05152 seconds
Time After: 0.05180 seconds
