Time Before: 0.00903 seconds
Time After: 0.01143 seconds
Time Taken: 0.00240 seconds
Time Before: 0.01153 seconds
Time After: 0.01195 seconds
Time Before: 0.01225 seconds
Time After: 0.01238 seconds
Time Before: 0.01324 seconds
Time After: 0.01564 seconds
Time Before: 0.01243 seconds
Time After: 0.01993 seconds
Time Taken: 0.00750 seconds
Time Before: 0.02548 seconds
Time After: 0.02590 seconds
Time Before: 0.02748 seconds
Time After: 0.02867 seconds
Time Before: 0.02472 seconds
Time After: 0.02889 seconds
Time Taken: 0.00418 seconds
Time Before: 0.04633 seconds
Time After: 0.04649 seconds
Time Before: 0.05611 seconds
Time After: 0.05735 seconds
Time Before: 0.06596 seconds
Time After: 0.06614 seconds
Time Before: 0.06864 seconds
Time After: 0.07012 seconds
UPDATE session SET lastactivity = 1785297705, location = '/forums/private.php?do=newpm&explain=1&u=104756', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.08737 seconds
Time After: 0.08801 seconds
Time Taken: 0.00064 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
