Time Before: 0.00147 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00245 seconds
Time Before: 0.00270 seconds
Time After: 0.00285 seconds
Time Before: 0.00374 seconds
Time After: 0.00689 seconds
Time Taken: 0.00315 seconds
Time Before: 0.00293 seconds
Time After: 0.01167 seconds
Time Taken: 0.00874 seconds
Time Before: 0.01379 seconds
Time After: 0.01440 seconds
Time Taken: 0.00061 seconds
Time Before: 0.01741 seconds
Time After: 0.01896 seconds
Time Taken: 0.00155 seconds
Time Before: 0.01316 seconds
Time After: 0.01913 seconds
Time Taken: 0.00597 seconds
Time Before: 0.02429 seconds
Time After: 0.02451 seconds
Time Before: 0.02648 seconds
Time After: 0.02770 seconds
Time Before: 0.03064 seconds
Time After: 0.03081 seconds
Time Before: 0.03341 seconds
Time After: 0.03486 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104766' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.05033 seconds
Time After: 0.05702 seconds
Time Taken: 0.00668 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
