Time Before: 0.00212 seconds
Time After: 0.00275 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00283 seconds
Time After: 0.00321 seconds
Time Before: 0.00346 seconds
Time After: 0.00362 seconds
Time Before: 0.00426 seconds
Time After: 0.00686 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00367 seconds
Time After: 0.01024 seconds
Time Taken: 0.00657 seconds
Time Before: 0.01203 seconds
Time After: 0.01241 seconds
Time Before: 0.01494 seconds
Time After: 0.01622 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01140 seconds
Time After: 0.01647 seconds
Time Taken: 0.00507 seconds
Memory After: 2,261.703 KB
Time Before: 0.02217 seconds
Time After: 0.02234 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02507 seconds
Time After: 0.02628 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.028012990951538
Time Before: 0.02918 seconds
Time After: 0.02935 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03127 seconds
Time After: 0.03267 seconds
Time Taken: 0.00140 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=104779', badlocation = 1
Time Before: 0.04621 seconds
Time After: 0.04649 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.045184850692749 seconds with 9 queries, spending 0.0080306529998779 doing MySQL queries and 0.037154197692871 doing PHP things.
