Time Before: 0.01850 seconds
Time After: 0.02643 seconds
Time Taken: 0.00794 seconds
Time Before: 0.02652 seconds
Time After: 0.02700 seconds
Time Before: 0.02721 seconds
Time After: 0.02734 seconds
Time Before: 0.02812 seconds
Time After: 0.03046 seconds
Time Taken: 0.00233 seconds
Time Before: 0.02742 seconds
Time After: 0.03459 seconds
Time Taken: 0.00717 seconds
Time Before: 0.04083 seconds
Time After: 0.04120 seconds
Time Before: 0.04364 seconds
Time After: 0.04484 seconds
Time Before: 0.04023 seconds
Time After: 0.04505 seconds
Time Taken: 0.00482 seconds
Time Before: 0.08127 seconds
Time After: 0.08141 seconds
Time Before: 0.09294 seconds
Time After: 0.09420 seconds
End call of global.php: 0.09628701210022
Time Before: 0.10203 seconds
Time After: 0.10218 seconds
Time Before: 0.10487 seconds
Time After: 0.10640 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=104780'
Time Before: 0.12727 seconds
Time After: 0.12752 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
Page generated in 0.1261191368103 seconds with 9 queries, spending 0.0078635215759277 doing MySQL queries and 0.11825561523438 doing PHP things.
