Time Before: 0.00786 seconds
Time After: 0.00995 seconds
Time Taken: 0.00209 seconds
Time Before: 0.01006 seconds
Time After: 0.01046 seconds
Time Before: 0.01070 seconds
Time After: 0.01083 seconds
Time Before: 0.01175 seconds
Time After: 0.01391 seconds
Time Taken: 0.00216 seconds
Time Before: 0.01090 seconds
Time After: 0.01957 seconds
Time Taken: 0.00867 seconds
Time Before: 0.02329 seconds
Time After: 0.02370 seconds
Time Before: 0.02689 seconds
Time After: 0.02828 seconds
Time Taken: 0.00138 seconds
Time Before: 0.02243 seconds
Time After: 0.02849 seconds
Time Taken: 0.00605 seconds
Time Before: 0.04493 seconds
Time After: 0.04508 seconds
Time Before: 0.05094 seconds
Time After: 0.05217 seconds
Time Before: 0.05901 seconds
Time After: 0.05923 seconds
Time Before: 0.06208 seconds
Time After: 0.06418 seconds
Time Taken: 0.00210 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104789', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.08093 seconds
Time After: 0.08125 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
