Time Before: 0.00177 seconds
Time After: 0.00276 seconds
Time Taken: 0.00099 seconds
Time Before: 0.00283 seconds
Time After: 0.00410 seconds
Time Before: 0.00484 seconds
Time After: 0.00514 seconds
Time Before: 0.00594 seconds
Time After: 0.00805 seconds
Time Taken: 0.00211 seconds
Time Before: 0.00522 seconds
Time After: 0.01147 seconds
Time Taken: 0.00625 seconds
Time Before: 0.01326 seconds
Time After: 0.01363 seconds
Time Before: 0.01683 seconds
Time After: 0.01810 seconds
Time Before: 0.01263 seconds
Time After: 0.01836 seconds
Time Taken: 0.00573 seconds
Time Before: 0.02571 seconds
Time After: 0.02584 seconds
Time Before: 0.02835 seconds
Time After: 0.02958 seconds
End call of global.php: 0.032323837280273
Time Before: 0.03395 seconds
Time After: 0.03411 seconds
Time Before: 0.03732 seconds
Time After: 0.03879 seconds
SET lastactivity = 1789147640, location = '/forums/private.php?do=newpm&explain=1&u=104797', badlocation = 1
Time Before: 0.05899 seconds
Time After: 0.05976 seconds
Time Taken: 0.00077 seconds
Page generated in 0.057730913162231 seconds with 9 queries, spending 0.0090899467468262 doing MySQL queries and 0.048640966415405 doing PHP things.
