Time Before: 0.00157 seconds
Time After: 0.00211 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00218 seconds
Time After: 0.00265 seconds
Time Before: 0.00290 seconds
Time After: 0.00302 seconds
Time Before: 0.00390 seconds
Time After: 0.00668 seconds
Time Taken: 0.00278 seconds
Time Before: 0.00309 seconds
Time After: 0.01158 seconds
Time Taken: 0.00849 seconds
Time Before: 0.01412 seconds
Time After: 0.01460 seconds
Time Before: 0.01789 seconds
Time After: 0.01915 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01330 seconds
Time After: 0.01942 seconds
Time Taken: 0.00612 seconds
Memory After: 2,261.703 KB
Time Before: 0.02510 seconds
Time After: 0.02529 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02740 seconds
Time After: 0.02865 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.030427217483521
Time Before: 0.03202 seconds
Time After: 0.03224 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03444 seconds
Time After: 0.03586 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=104809'
Time Before: 0.04812 seconds
Time After: 0.04836 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.047237157821655 seconds with 9 queries, spending 0.0084543228149414 doing MySQL queries and 0.038782835006714 doing PHP things.
