Time Before: 0.00138 seconds
Time After: 0.00192 seconds
Time Taken: 0.00055 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00200 seconds
Time After: 0.00254 seconds
Time Taken: 0.00054 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00278 seconds
Time After: 0.00295 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00373 seconds
Time After: 0.00725 seconds
Time Taken: 0.00352 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00305 seconds
Time After: 0.01063 seconds
Time Taken: 0.00758 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01248 seconds
Time After: 0.01285 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01538 seconds
Time After: 0.01698 seconds
Time Taken: 0.00160 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.01192 seconds
Time After: 0.01721 seconds
Time Taken: 0.00529 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.02339 seconds
Time After: 0.02356 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.02643 seconds
Time After: 0.02766 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
End call of global.php: 0.029371976852417
Time Before: 0.03071 seconds
Time After: 0.03086 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.03284 seconds
Time After: 0.03432 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=104810', badlocation = 1
Time Before: 0.04666 seconds
Time After: 0.04701 seconds
Memory Before: 4,918.680 KB
Memory After: 4,918.906 KB
Page generated in 0.045802116394043 seconds with 9 queries, spending 0.009584903717041 doing MySQL queries and 0.036217212677002 doing PHP things.
