Time Before: 0.01697 seconds
Time After: 0.02155 seconds
Time Taken: 0.00459 seconds
Time Before: 0.02167 seconds
Time After: 0.02245 seconds
Time Taken: 0.00079 seconds
Time Before: 0.02271 seconds
Time After: 0.02284 seconds
Time Before: 0.02383 seconds
Time After: 0.02731 seconds
Time Taken: 0.00347 seconds
Time Before: 0.02292 seconds
Time After: 0.03125 seconds
Time Taken: 0.00833 seconds
Time Before: 0.03788 seconds
Time After: 0.03830 seconds
Time Before: 0.04165 seconds
Time After: 0.04286 seconds
Time Before: 0.03722 seconds
Time After: 0.04310 seconds
Time Taken: 0.00588 seconds
Time Before: 0.06947 seconds
Time After: 0.06961 seconds
Time Before: 0.08272 seconds
Time After: 0.08398 seconds
Time Before: 0.09427 seconds
Time After: 0.09445 seconds
Time Before: 0.09774 seconds
Time After: 0.10037 seconds
Time Taken: 0.00264 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104813' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.11725 seconds
Time After: 0.11752 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
