Time Before: 0.00977 seconds
Time After: 0.01293 seconds
Time Taken: 0.00316 seconds
Time Before: 0.01302 seconds
Time After: 0.01367 seconds
Time Taken: 0.00065 seconds
Time Before: 0.01403 seconds
Time After: 0.01431 seconds
Time Before: 0.01503 seconds
Time After: 0.01734 seconds
Time Taken: 0.00230 seconds
Time Before: 0.01437 seconds
Time After: 0.02165 seconds
Time Taken: 0.00728 seconds
Time Before: 0.02549 seconds
Time After: 0.02587 seconds
Time Before: 0.02854 seconds
Time After: 0.02993 seconds
Time Taken: 0.00139 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02482 seconds
Time After: 0.03016 seconds
Time Taken: 0.00534 seconds
Memory After: 2,261.703 KB
Time Before: 0.04569 seconds
Time After: 0.04589 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.05318 seconds
Time After: 0.05452 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.056719064712524
Time Before: 0.06094 seconds
Time After: 0.06111 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.06370 seconds
Time After: 0.06517 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=104828', badlocation = 1
Time Before: 0.08394 seconds
Time After: 0.08427 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.082629919052124 seconds with 9 queries, spending 0.0085241794586182 doing MySQL queries and 0.074105739593506 doing PHP things.
