Time Before: 0.01281 seconds
Time After: 0.02272 seconds
Time Taken: 0.00991 seconds
Time Before: 0.02284 seconds
Time After: 0.02341 seconds
Time Taken: 0.00057 seconds
Time Before: 0.02359 seconds
Time After: 0.02375 seconds
Time Before: 0.02444 seconds
Time After: 0.02877 seconds
Time Taken: 0.00434 seconds
Time Before: 0.02384 seconds
Time After: 0.03309 seconds
Time Taken: 0.00925 seconds
Time Before: 0.04432 seconds
Time After: 0.04475 seconds
Time Before: 0.04630 seconds
Time After: 0.04752 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04352 seconds
Time After: 0.04774 seconds
Time Taken: 0.00422 seconds
Memory After: 2,261.820 KB
Time Before: 0.06483 seconds
Time After: 0.06498 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.08515 seconds
Time After: 0.08638 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.09758 seconds
Time After: 0.09772 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.10018 seconds
Time After: 0.10159 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789148414, location = '/forums/private.php?do=newpm&explain=1&u=104843' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.12300 seconds
Time After: 0.12357 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
