Time Before: 0.00195 seconds
Time After: 0.00254 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00261 seconds
Time After: 0.00336 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00392 seconds
Time After: 0.00421 seconds
Time Before: 0.00512 seconds
Time After: 0.00725 seconds
Time Taken: 0.00213 seconds
Time Before: 0.00429 seconds
Time After: 0.01213 seconds
Time Taken: 0.00784 seconds
Time Before: 0.01423 seconds
Time After: 0.01464 seconds
Time Before: 0.01723 seconds
Time After: 0.01843 seconds
Time Before: 0.01350 seconds
Time After: 0.01870 seconds
Time Taken: 0.00520 seconds
Time Before: 0.02663 seconds
Time After: 0.02678 seconds
Time Before: 0.02919 seconds
Time After: 0.03046 seconds
End call of global.php: 0.032822132110596
Time Before: 0.03417 seconds
Time After: 0.03432 seconds
Time Before: 0.03690 seconds
Time After: 0.03833 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=104855'
Time Before: 0.05413 seconds
Time After: 0.05440 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.053205966949463 seconds with 9 queries, spending 0.0080387592315674 doing MySQL queries and 0.045167207717896 doing PHP things.
