Time Before: 0.02463 seconds
Time After: 0.03066 seconds
Time Taken: 0.00603 seconds
Time Before: 0.03077 seconds
Time After: 0.03122 seconds
Time Before: 0.03150 seconds
Time After: 0.03166 seconds
Time Before: 0.03244 seconds
Time After: 0.03484 seconds
Time Taken: 0.00239 seconds
Time Before: 0.03173 seconds
Time After: 0.03838 seconds
Time Taken: 0.00664 seconds
Time Before: 0.04628 seconds
Time After: 0.04672 seconds
Time Before: 0.04926 seconds
Time After: 0.05049 seconds
Time Before: 0.04561 seconds
Time After: 0.05074 seconds
Time Taken: 0.00513 seconds
Time Before: 0.06727 seconds
Time After: 0.06746 seconds
Time Before: 0.08203 seconds
Time After: 0.08330 seconds
End call of global.php: 0.085387945175171
Time Before: 0.09270 seconds
Time After: 0.09286 seconds
Time Before: 0.09558 seconds
Time After: 0.09707 seconds
SET lastactivity = 1783023904, location = '/forums/private.php?do=newpm&explain=1&u=104863'
Time Before: 0.11616 seconds
Time After: 0.11646 seconds
Page generated in 0.11520791053772 seconds with 9 queries, spending 0.0080721378326416 doing MySQL queries and 0.10713577270508 doing PHP things.
