Time Before: 0.02626 seconds
Time After: 0.03404 seconds
Time Taken: 0.00778 seconds
Time Before: 0.03413 seconds
Time After: 0.03454 seconds
Time Before: 0.03480 seconds
Time After: 0.03494 seconds
Time Before: 0.03580 seconds
Time After: 0.03831 seconds
Time Taken: 0.00251 seconds
Time Before: 0.03502 seconds
Time After: 0.04221 seconds
Time Taken: 0.00718 seconds
Time Before: 0.05259 seconds
Time After: 0.05303 seconds
Time Before: 0.05620 seconds
Time After: 0.05838 seconds
Time Taken: 0.00218 seconds
Time Before: 0.05179 seconds
Time After: 0.05862 seconds
Time Taken: 0.00683 seconds
Time Before: 0.10390 seconds
Time After: 0.10412 seconds
Time Before: 0.12235 seconds
Time After: 0.12360 seconds
Time Before: 0.14025 seconds
Time After: 0.14040 seconds
Time Before: 0.14325 seconds
Time After: 0.14472 seconds
UPDATE session SET lastactivity = 1776613456, location = '/forums/private.php?do=newpm&explain=1&u=104870' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.17614 seconds
Time After: 0.17658 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
