Time Before: 0.01252 seconds
Time After: 0.02622 seconds
Time Taken: 0.01369 seconds
Time Before: 0.02631 seconds
Time After: 0.02674 seconds
Time Before: 0.02697 seconds
Time After: 0.02710 seconds
Time Before: 0.02789 seconds
Time After: 0.03071 seconds
Time Taken: 0.00282 seconds
Time Before: 0.02717 seconds
Time After: 0.03441 seconds
Time Taken: 0.00724 seconds
Time Before: 0.04191 seconds
Time After: 0.04234 seconds
Time Before: 0.04555 seconds
Time After: 0.04717 seconds
Time Taken: 0.00162 seconds
Time Before: 0.04115 seconds
Time After: 0.04744 seconds
Time Taken: 0.00629 seconds
Time Before: 0.08269 seconds
Time After: 0.08282 seconds
Time Before: 0.10662 seconds
Time After: 0.10789 seconds
Time Before: 0.12073 seconds
Time After: 0.12091 seconds
Time Before: 0.12349 seconds
Time After: 0.12492 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104873' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.14691 seconds
Time After: 0.14716 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
