Time Before: 0.00140 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00398 seconds
Time Taken: 0.00202 seconds
Time Before: 0.00428 seconds
Time After: 0.00450 seconds
Time Before: 0.00555 seconds
Time After: 0.00866 seconds
Time Taken: 0.00311 seconds
Time Before: 0.00458 seconds
Time After: 0.01204 seconds
Time Taken: 0.00746 seconds
Time Before: 0.01432 seconds
Time After: 0.01482 seconds
Time Before: 0.01791 seconds
Time After: 0.01911 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01362 seconds
Time After: 0.01934 seconds
Time Taken: 0.00573 seconds
Memory After: 2,261.703 KB
Time Before: 0.02456 seconds
Time After: 0.02469 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02692 seconds
Time After: 0.02824 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.03114 seconds
Time After: 0.03129 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03348 seconds
Time After: 0.03492 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104875', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04878 seconds
Time After: 0.04970 seconds
Time Taken: 0.00092 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
