Time Before: 0.01032 seconds
Time After: 0.01344 seconds
Time Taken: 0.00312 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.01352 seconds
Time After: 0.01401 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.01432 seconds
Time After: 0.01449 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.01544 seconds
Time After: 0.01805 seconds
Time Taken: 0.00261 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.01458 seconds
Time After: 0.02231 seconds
Time Taken: 0.00773 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.02670 seconds
Time After: 0.02715 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.02973 seconds
Time After: 0.03092 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.02596 seconds
Time After: 0.03117 seconds
Time Taken: 0.00521 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.05850 seconds
Time After: 0.05866 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.08793 seconds
Time After: 0.08918 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.091173887252808
Time Before: 0.10641 seconds
Time After: 0.10659 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.11080 seconds
Time After: 0.11242 seconds
Time Taken: 0.00163 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1772947760, location = '/forums/private.php?do=newpm&explain=1&u=104878'
WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.13156 seconds
Time After: 0.13181 seconds
Memory Before: 5,997.945 KB
Memory After: 5,998.164 KB
Page generated in 0.13042306900024 seconds with 9 queries, spending 0.0083901882171631 doing MySQL queries and 0.12203288078308 doing PHP things.
