Time Before: 0.02143 seconds
Time After: 0.02817 seconds
Time Taken: 0.00675 seconds
Time Before: 0.02828 seconds
Time After: 0.02879 seconds
Time Before: 0.02902 seconds
Time After: 0.02914 seconds
Time Before: 0.02983 seconds
Time After: 0.03182 seconds
Time Taken: 0.00199 seconds
Time Before: 0.02919 seconds
Time After: 0.03572 seconds
Time Taken: 0.00653 seconds
Time Before: 0.04246 seconds
Time After: 0.04285 seconds
Time Before: 0.04531 seconds
Time After: 0.04653 seconds
Time Before: 0.04188 seconds
Time After: 0.04671 seconds
Time Taken: 0.00483 seconds
Time Before: 0.08192 seconds
Time After: 0.08209 seconds
Time Before: 2.82716 seconds
Time After: 2.82863 seconds
Time Before: 2.83957 seconds
Time After: 2.83978 seconds
Time Before: 2.84246 seconds
Time After: 2.84395 seconds
UPDATE session SET lastactivity = 1776583646, location = '/forums/private.php?do=newpm&explain=1&u=104914', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 2.86368 seconds
Time After: 2.86394 seconds
