Time Before: 0.01431 seconds
Time After: 0.02202 seconds
Time Taken: 0.00771 seconds
Time Before: 0.02212 seconds
Time After: 0.02267 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02293 seconds
Time After: 0.02305 seconds
Time Before: 0.02377 seconds
Time After: 0.02595 seconds
Time Taken: 0.00218 seconds
Time Before: 0.02311 seconds
Time After: 0.03083 seconds
Time Before: 0.03764 seconds
Time After: 0.03801 seconds
Time Before: 0.04065 seconds
Time After: 0.04187 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03701 seconds
Time After: 0.04206 seconds
Time Taken: 0.00505 seconds
Memory After: 2,261.820 KB
Time Before: 0.06665 seconds
Time After: 0.06683 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.17482 seconds
Time After: 0.17669 seconds
Time Taken: 0.00186 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.18527 seconds
Time After: 0.18552 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.18780 seconds
Time After: 0.18932 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788894189, location = '/forums/private.php?do=newpm&explain=1&u=104923' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.20529 seconds
Time After: 0.20554 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
