Time Before: 0.00691 seconds
Time After: 0.00956 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00965 seconds
Time After: 0.01008 seconds
Time Before: 0.01033 seconds
Time After: 0.01047 seconds
Time Before: 0.01131 seconds
Time After: 0.01501 seconds
Time Taken: 0.00370 seconds
Time Before: 0.01053 seconds
Time After: 0.01940 seconds
Time Taken: 0.00887 seconds
Time Before: 0.02286 seconds
Time After: 0.02321 seconds
Time Before: 0.02560 seconds
Time After: 0.02680 seconds
Time Before: 0.02221 seconds
Time After: 0.02704 seconds
Time Taken: 0.00483 seconds
Time Before: 0.04235 seconds
Time After: 0.04247 seconds
Time Before: 0.05076 seconds
Time After: 0.05209 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.054002046585083
Time Before: 0.05660 seconds
Time After: 0.05674 seconds
Time Before: 0.05895 seconds
Time After: 0.06041 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=104951', badlocation = 1
Time Before: 0.07587 seconds
Time After: 0.07614 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.074910879135132 seconds with 9 queries, spending 0.0091450214385986 doing MySQL queries and 0.065765857696533 doing PHP things.
