Time Before: 0.00177 seconds
Time After: 0.00250 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00266 seconds
Time After: 0.00315 seconds
Time Before: 0.00342 seconds
Time After: 0.00371 seconds
Time Before: 0.00451 seconds
Time After: 0.00665 seconds
Time Taken: 0.00214 seconds
Time Before: 0.00378 seconds
Time After: 0.01179 seconds
Time Taken: 0.00801 seconds
Time Before: 0.01381 seconds
Time After: 0.01429 seconds
Time Before: 0.01741 seconds
Time After: 0.01938 seconds
Time Taken: 0.00197 seconds
Time Before: 0.01296 seconds
Time After: 0.01959 seconds
Time Taken: 0.00662 seconds
Time Before: 0.02526 seconds
Time After: 0.02550 seconds
Time Before: 0.02778 seconds
Time After: 0.02917 seconds
Time Taken: 0.00139 seconds
Time Before: 0.03420 seconds
Time After: 0.03435 seconds
Time Before: 0.03754 seconds
Time After: 0.03898 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104956', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05608 seconds
Time After: 0.05631 seconds
