Time Before: 0.00143 seconds
Time After: 0.00197 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00204 seconds
Time After: 0.00256 seconds
Time Before: 0.00279 seconds
Time After: 0.00290 seconds
Time Before: 0.00355 seconds
Time After: 0.00592 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00295 seconds
Time After: 0.01072 seconds
Time Taken: 0.00777 seconds
Time Before: 0.01300 seconds
Time After: 0.01319 seconds
Time Before: 0.01582 seconds
Time After: 0.01698 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01231 seconds
Time After: 0.01717 seconds
Time Taken: 0.00486 seconds
Time Before: 0.02227 seconds
Time After: 0.02238 seconds
Time Before: 0.02432 seconds
Time After: 0.02551 seconds
End call of global.php: 0.027138948440552
Time Before: 0.02843 seconds
Time After: 0.02865 seconds
Time Before: 0.03071 seconds
Time After: 0.03216 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=104968', badlocation = 1
Time Before: 0.04511 seconds
Time After: 0.08453 seconds
Time Taken: 0.03943 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
Page generated in 0.044178009033203 seconds with 9 queries, spending 0.046755790710449 doing MySQL queries and -0.0025777816772461 doing PHP things.
