Time Before: 0.02145 seconds
Time After: 0.02808 seconds
Time Taken: 0.00663 seconds
Time Before: 0.02815 seconds
Time After: 0.02856 seconds
Time Before: 0.02880 seconds
Time After: 0.02896 seconds
Time Before: 0.02970 seconds
Time After: 0.03161 seconds
Time Taken: 0.00191 seconds
Time Before: 0.02902 seconds
Time After: 0.03556 seconds
Time Taken: 0.00655 seconds
Time Before: 0.04298 seconds
Time After: 0.04339 seconds
Time Before: 0.04595 seconds
Time After: 0.04718 seconds
Time Before: 0.04228 seconds
Time After: 0.04738 seconds
Time Taken: 0.00511 seconds
Time Before: 0.08354 seconds
Time After: 0.08372 seconds
Time Before: 0.09693 seconds
Time After: 0.09819 seconds
Time Before: 0.11173 seconds
Time After: 0.11191 seconds
Time Before: 0.11427 seconds
Time After: 0.11572 seconds
UPDATE session SET lastactivity = 1783067953, location = '/forums/private.php?do=newpm&explain=1&u=104969' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.13442 seconds
Time After: 0.13472 seconds
