Time Before: 0.02586 seconds
Time After: 0.03190 seconds
Time Taken: 0.00604 seconds
Time Before: 0.03203 seconds
Time After: 0.03246 seconds
Time Before: 0.03276 seconds
Time After: 0.03293 seconds
Time Before: 0.03397 seconds
Time After: 0.03614 seconds
Time Taken: 0.00217 seconds
Time Before: 0.03301 seconds
Time After: 0.04051 seconds
Time Taken: 0.00750 seconds
Time Before: 0.05192 seconds
Time After: 0.05239 seconds
Time Before: 0.05701 seconds
Time After: 0.05821 seconds
Time Before: 0.05124 seconds
Time After: 0.05842 seconds
Time Taken: 0.00719 seconds
Time Before: 0.09824 seconds
Time After: 0.09845 seconds
Time Before: 0.11506 seconds
Time After: 0.11629 seconds
End call of global.php: 0.11864900588989
Time Before: 0.12819 seconds
Time After: 0.12836 seconds
Time Before: 0.13093 seconds
Time After: 0.13240 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=105000', badlocation = 1
Time Before: 0.14941 seconds
Time After: 0.14973 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.14836287498474 seconds with 9 queries, spending 0.0078434944152832 doing MySQL queries and 0.14051938056946 doing PHP things.
