Time Before: 0.00149 seconds
Time After: 0.00210 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00217 seconds
Time After: 0.00277 seconds
Time Before: 0.00308 seconds
Time After: 0.00327 seconds
Time Before: 0.00402 seconds
Time After: 0.00668 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00334 seconds
Time After: 0.01003 seconds
Time Taken: 0.00669 seconds
Time Before: 0.01190 seconds
Time After: 0.01230 seconds
Time Before: 0.01478 seconds
Time After: 0.01602 seconds
Time Before: 0.01124 seconds
Time After: 0.01620 seconds
Time Taken: 0.00495 seconds
Time Before: 0.02118 seconds
Time After: 0.02140 seconds
Time Before: 0.02363 seconds
Time After: 0.02486 seconds
Time Before: 0.02774 seconds
Time After: 0.02791 seconds
Time Before: 0.02992 seconds
Time After: 0.03137 seconds
UPDATE session SET lastactivity = 1783080968, location = '/forums/private.php?do=newpm&explain=1&u=105006', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.04390 seconds
Time After: 0.04415 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
