Time Before: 0.00136 seconds
Time After: 0.00186 seconds
Time Before: 0.00193 seconds
Time After: 0.00239 seconds
Time Before: 0.00259 seconds
Time After: 0.00274 seconds
Time Before: 0.00340 seconds
Time After: 0.00571 seconds
Time Taken: 0.00230 seconds
Time Before: 0.00279 seconds
Time After: 0.01105 seconds
Time Taken: 0.00826 seconds
Time Before: 0.01335 seconds
Time After: 0.01360 seconds
Time Before: 0.01505 seconds
Time After: 0.01624 seconds
Time Before: 0.01255 seconds
Time After: 0.01641 seconds
Time Taken: 0.00387 seconds
Time Before: 0.02306 seconds
Time After: 0.02322 seconds
Time Before: 0.02683 seconds
Time After: 0.02812 seconds
Time Before: 0.03099 seconds
Time After: 0.03114 seconds
Time Before: 0.03308 seconds
Time After: 0.03454 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105028' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.05206 seconds
Time After: 0.05230 seconds
