Time Before: 0.00168 seconds
Time After: 0.00208 seconds
Time Before: 0.00216 seconds
Time After: 0.00253 seconds
Time Before: 0.00273 seconds
Time After: 0.00285 seconds
Time Before: 0.00370 seconds
Time After: 0.00591 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00289 seconds
Time After: 0.01068 seconds
Time Taken: 0.00779 seconds
Time Before: 0.01261 seconds
Time After: 0.01299 seconds
Time Before: 0.01459 seconds
Time After: 0.01579 seconds
Time Before: 0.01196 seconds
Time After: 0.01597 seconds
Time Taken: 0.00401 seconds
Time Before: 0.02113 seconds
Time After: 0.02124 seconds
Time Before: 0.02301 seconds
Time After: 0.02425 seconds
Time Before: 0.02735 seconds
Time After: 0.02750 seconds
Time Before: 0.02980 seconds
Time After: 0.03123 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105032' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.04476 seconds
Time After: 0.04514 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
