Time Before: 0.02531 seconds
Time After: 0.03287 seconds
Time Taken: 0.00757 seconds
Time Before: 0.03295 seconds
Time After: 0.03345 seconds
Time Before: 0.03365 seconds
Time After: 0.03385 seconds
Time Before: 0.03475 seconds
Time After: 0.03706 seconds
Time Taken: 0.00231 seconds
Time Before: 0.03393 seconds
Time After: 0.04260 seconds
Time Taken: 0.00868 seconds
Time Before: 0.05226 seconds
Time After: 0.05263 seconds
Time Before: 0.05510 seconds
Time After: 0.05643 seconds
Time Taken: 0.00133 seconds
Time Before: 0.05152 seconds
Time After: 0.05669 seconds
Time Taken: 0.00517 seconds
Time Before: 0.09411 seconds
Time After: 0.09426 seconds
Time Before: 0.11743 seconds
Time After: 0.11906 seconds
Time Taken: 0.00163 seconds
Time Before: 0.13253 seconds
Time After: 0.13272 seconds
Time Before: 0.13562 seconds
Time After: 0.13711 seconds
UPDATE session SET lastactivity = 1776800132, location = '/forums/private.php?do=newpm&explain=1&u=105036', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.15823 seconds
Time After: 0.15856 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
