Time Before: 0.00149 seconds
Time After: 0.00203 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00210 seconds
Time After: 0.00253 seconds
Time Before: 0.00279 seconds
Time After: 0.00295 seconds
Time Before: 0.00377 seconds
Time After: 0.00656 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00300 seconds
Time After: 0.01002 seconds
Time Taken: 0.00702 seconds
Time Before: 0.01216 seconds
Time After: 0.01263 seconds
Time Before: 0.01513 seconds
Time After: 0.01635 seconds
Time Before: 0.01153 seconds
Time After: 0.01660 seconds
Time Taken: 0.00506 seconds
Time Before: 0.02320 seconds
Time After: 0.02342 seconds
Time Before: 0.02710 seconds
Time After: 0.02843 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.030994892120361
Time Before: 0.03256 seconds
Time After: 0.03274 seconds
Time Before: 0.03527 seconds
Time After: 0.03674 seconds
SET lastactivity = 1782957370, location = '/forums/private.php?do=newpm&explain=1&u=105039'
Time Before: 0.05080 seconds
Time After: 0.05108 seconds
Page generated in 0.049823999404907 seconds with 9 queries, spending 0.0085277557373047 doing MySQL queries and 0.041296243667603 doing PHP things.
