Time Before: 0.00154 seconds
Time After: 0.00202 seconds
Time Before: 0.00209 seconds
Time After: 0.00252 seconds
Time Before: 0.00272 seconds
Time After: 0.00283 seconds
Time Before: 0.00358 seconds
Time After: 0.00565 seconds
Time Taken: 0.00207 seconds
Time Before: 0.00288 seconds
Time After: 0.00997 seconds
Time Taken: 0.00709 seconds
Time Before: 0.01192 seconds
Time After: 0.01241 seconds
Time Before: 0.01539 seconds
Time After: 0.01662 seconds
Time Before: 0.01118 seconds
Time After: 0.01682 seconds
Time Taken: 0.00564 seconds
Time Before: 0.02376 seconds
Time After: 0.02392 seconds
Time Before: 0.02580 seconds
Time After: 0.02704 seconds
End call of global.php: 0.028784036636353
Time Before: 0.03023 seconds
Time After: 0.03037 seconds
Time Before: 0.03253 seconds
Time After: 0.03400 seconds
SET lastactivity = 1776647704, location = '/forums/private.php?do=newpm&explain=1&u=105054', badlocation = 1
Time Before: 0.04875 seconds
Time After: 0.04906 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.047807931900024 seconds with 9 queries, spending 0.0076658725738525 doing MySQL queries and 0.040142059326172 doing PHP things.
