Time Before: 0.01326 seconds
Time After: 0.01753 seconds
Time Taken: 0.00426 seconds
Time Before: 0.01761 seconds
Time After: 0.01853 seconds
Time Taken: 0.00092 seconds
Time Before: 0.01882 seconds
Time After: 0.01896 seconds
Time Before: 0.01974 seconds
Time After: 0.02202 seconds
Time Taken: 0.00228 seconds
Time Before: 0.01902 seconds
Time After: 0.02586 seconds
Time Taken: 0.00684 seconds
Time Before: 0.03051 seconds
Time After: 0.03088 seconds
Time Before: 0.03241 seconds
Time After: 0.03370 seconds
Time Before: 0.02987 seconds
Time After: 0.03392 seconds
Time Taken: 0.00405 seconds
Memory After: 2,885.109 KB
Memory Used: 132.781 KB
Time Before: 0.05759 seconds
Time After: 0.05780 seconds
Memory Before: 3,438.211 KB
Memory After: 3,438.727 KB
Time Before: 0.06830 seconds
Time After: 0.06981 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,525.906 KB
Memory After: 3,526.500 KB
Time Before: 0.07844 seconds
Time After: 0.07867 seconds
Memory Before: 4,163.813 KB
Memory After: 4,164.242 KB
Time Before: 0.08163 seconds
Time After: 0.08315 seconds
Memory Before: 4,445.375 KB
Memory After: 4,447.063 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105059' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.09984 seconds
Time After: 0.10053 seconds
Time Taken: 0.00069 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
