Time Before: 0.00141 seconds
Time After: 0.00194 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00201 seconds
Time After: 0.00248 seconds
Time Before: 0.00281 seconds
Time After: 0.00294 seconds
Time Before: 0.00393 seconds
Time After: 0.00688 seconds
Time Taken: 0.00295 seconds
Time Before: 0.00302 seconds
Time After: 0.01216 seconds
Time Taken: 0.00914 seconds
Time Before: 0.01471 seconds
Time After: 0.01511 seconds
Time Before: 0.01794 seconds
Time After: 0.01921 seconds
Time Before: 0.01391 seconds
Time After: 0.01947 seconds
Time Taken: 0.00557 seconds
Time Before: 0.02645 seconds
Time After: 0.02658 seconds
Time Before: 0.02890 seconds
Time After: 0.03047 seconds
Time Taken: 0.00156 seconds
Time Before: 0.03352 seconds
Time After: 0.03367 seconds
Time Before: 0.03655 seconds
Time After: 0.03810 seconds
Time Taken: 0.00154 seconds
UPDATE session SET lastactivity = 1783211410, location = '/forums/private.php?do=newpm&explain=1&u=10508', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.05215 seconds
Time After: 0.05253 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
