Time Before: 0.00278 seconds
Time After: 0.00353 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00363 seconds
Time After: 0.00413 seconds
Time Before: 0.00440 seconds
Time After: 0.00455 seconds
Time Before: 0.00543 seconds
Time After: 0.00763 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00463 seconds
Time After: 0.01332 seconds
Time Taken: 0.00870 seconds
Time Before: 0.01625 seconds
Time After: 0.01722 seconds
Time Taken: 0.00097 seconds
Time Before: 0.01978 seconds
Time After: 0.02100 seconds
Time Before: 0.01542 seconds
Time After: 0.02127 seconds
Time Taken: 0.00584 seconds
Time Before: 0.02894 seconds
Time After: 0.02911 seconds
Time Before: 0.03187 seconds
Time After: 0.03313 seconds
End call of global.php: 0.035061836242676
Time Before: 0.03656 seconds
Time After: 0.03673 seconds
Time Before: 0.03909 seconds
Time After: 0.04053 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=105087'
Time Before: 0.05706 seconds
Time After: 0.05738 seconds
Page generated in 0.056006908416748 seconds with 9 queries, spending 0.0083816051483154 doing MySQL queries and 0.047625303268433 doing PHP things.
