Time Before: 0.02219 seconds
Time After: 0.03086 seconds
Time Taken: 0.00867 seconds
Time Before: 0.03096 seconds
Time After: 0.03161 seconds
Time Taken: 0.00065 seconds
Time Before: 0.03198 seconds
Time After: 0.03217 seconds
Time Before: 0.03298 seconds
Time After: 0.03520 seconds
Time Taken: 0.00222 seconds
Time Before: 0.03225 seconds
Time After: 0.03963 seconds
Time Taken: 0.00739 seconds
Time Before: 0.04846 seconds
Time After: 0.04886 seconds
Time Before: 0.05135 seconds
Time After: 0.05259 seconds
Time Before: 0.04770 seconds
Time After: 0.05287 seconds
Time Taken: 0.00517 seconds
Time Before: 0.07905 seconds
Time After: 0.07925 seconds
Time Before: 0.09897 seconds
Time After: 0.10022 seconds
Time Before: 0.11478 seconds
Time After: 0.11499 seconds
Time Before: 0.11772 seconds
Time After: 0.11922 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105126', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.14051 seconds
Time After: 0.14081 seconds
