Time Before: 0.00156 seconds
Time After: 0.00209 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00216 seconds
Time After: 0.00259 seconds
Time Before: 0.00279 seconds
Time After: 0.00291 seconds
Time Before: 0.00357 seconds
Time After: 0.00616 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00297 seconds
Time After: 0.00968 seconds
Time Taken: 0.00671 seconds
Time Before: 0.01157 seconds
Time After: 0.01192 seconds
Time Before: 0.01349 seconds
Time After: 0.01472 seconds
Time Before: 0.01097 seconds
Time After: 0.01498 seconds
Time Taken: 0.00400 seconds
Time Before: 0.02037 seconds
Time After: 0.02056 seconds
Time Before: 0.02243 seconds
Time After: 0.02369 seconds
End call of global.php: 0.026208877563477
Time Before: 0.02758 seconds
Time After: 0.02778 seconds
Time Before: 0.03068 seconds
Time After: 0.03216 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=105156', badlocation = 1
Time Before: 0.04819 seconds
Time After: 0.04852 seconds
Page generated in 0.047186851501465 seconds with 9 queries, spending 0.0081644058227539 doing MySQL queries and 0.039022445678711 doing PHP things.
