Time Before: 0.00209 seconds
Time After: 0.00268 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00278 seconds
Time After: 0.00327 seconds
Time Before: 0.00360 seconds
Time After: 0.00381 seconds
Time Before: 0.00456 seconds
Time After: 0.00744 seconds
Time Taken: 0.00288 seconds
Time Before: 0.00389 seconds
Time After: 0.01086 seconds
Time Taken: 0.00697 seconds
Time Before: 0.01259 seconds
Time After: 0.01301 seconds
Time Before: 0.01571 seconds
Time After: 0.01697 seconds
Time Before: 0.01201 seconds
Time After: 0.01721 seconds
Time Taken: 0.00520 seconds
Time Before: 0.02436 seconds
Time After: 0.02460 seconds
Time Before: 0.02693 seconds
Time After: 0.02825 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.030941963195801
Time Before: 0.03235 seconds
Time After: 0.03253 seconds
Time Before: 0.03544 seconds
Time After: 0.03693 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=105183'
Time Before: 0.04943 seconds
Time After: 0.04979 seconds
Page generated in 0.048512935638428 seconds with 9 queries, spending 0.0088329315185547 doing MySQL queries and 0.039680004119873 doing PHP things.
