Time Before: 0.01712 seconds
Time After: 0.02311 seconds
Time Taken: 0.00599 seconds
Time Before: 0.02320 seconds
Time After: 0.02368 seconds
Time Before: 0.02409 seconds
Time After: 0.02424 seconds
Time Before: 0.02519 seconds
Time After: 0.02817 seconds
Time Taken: 0.00298 seconds
Time Before: 0.02433 seconds
Time After: 0.03301 seconds
Time Taken: 0.00868 seconds
Time Before: 0.03841 seconds
Time After: 0.03875 seconds
Time Before: 0.04017 seconds
Time After: 0.04142 seconds
Time Before: 0.03768 seconds
Time After: 0.04163 seconds
Time Taken: 0.00395 seconds
Time Before: 0.06778 seconds
Time After: 0.06798 seconds
Time Before: 0.08157 seconds
Time After: 0.08281 seconds
End call of global.php: 0.084924936294556
Time Before: 0.08968 seconds
Time After: 0.08986 seconds
Time Before: 0.09229 seconds
Time After: 0.09380 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1784738044, location = '/forums/private.php?do=newpm&explain=1&u=105186', badlocation = 1
Time Before: 0.11310 seconds
Time After: 0.11344 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.11186695098877 seconds with 9 queries, spending 0.0086791515350342 doing MySQL queries and 0.10318779945374 doing PHP things.
