Time Before: 0.02201 seconds
Time After: 0.03299 seconds
Time Taken: 0.01098 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.03311 seconds
Time After: 0.03355 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.03408 seconds
Time After: 0.03424 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.03506 seconds
Time After: 0.03743 seconds
Time Taken: 0.00237 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.03430 seconds
Time After: 0.04133 seconds
Time Taken: 0.00704 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.05226 seconds
Time After: 0.05266 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.05527 seconds
Time After: 0.05647 seconds
Memory Before: 2,771.656 KB
Memory After: 2,771.516 KB
Time Before: 0.05156 seconds
Time After: 0.05670 seconds
Time Taken: 0.00514 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.547 KB
Time Before: 0.09804 seconds
Time After: 0.09819 seconds
Memory Before: 3,437.688 KB
Memory After: 3,438.203 KB
Time Before: 0.11112 seconds
Time After: 0.11237 seconds
Memory Before: 3,525.500 KB
Memory After: 3,526.094 KB
Time Before: 0.12110 seconds
Time After: 0.12127 seconds
Memory Before: 4,163.391 KB
Memory After: 4,163.820 KB
Time Before: 0.12376 seconds
Time After: 0.12520 seconds
Memory Before: 4,444.953 KB
Memory After: 4,446.641 KB
UPDATE session SET lastactivity = 1783067943, location = '/forums/private.php?do=newpm&explain=1&u=105210' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.14196 seconds
Time After: 0.14222 seconds
Memory Before: 4,918.805 KB
Memory After: 4,919.031 KB
