Time Before: 0.01679 seconds
Time After: 0.01975 seconds
Time Taken: 0.00295 seconds
Time Before: 0.01983 seconds
Time After: 0.02022 seconds
Time Before: 0.02045 seconds
Time After: 0.02061 seconds
Time Before: 0.02147 seconds
Time After: 0.02378 seconds
Time Taken: 0.00231 seconds
Time Before: 0.02069 seconds
Time After: 0.02889 seconds
Time Taken: 0.00820 seconds
Time Before: 0.03374 seconds
Time After: 0.03413 seconds
Time Before: 0.03681 seconds
Time After: 0.03811 seconds
Time Before: 0.03291 seconds
Time After: 0.03832 seconds
Time Taken: 0.00541 seconds
Time Before: 0.07012 seconds
Time After: 0.07025 seconds
Time Before: 0.08444 seconds
Time After: 0.08577 seconds
Time Taken: 0.00133 seconds
Time Before: 0.09290 seconds
Time After: 0.09305 seconds
Time Before: 0.09540 seconds
Time After: 0.09691 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105214' WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.11454 seconds
Time After: 0.11482 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
