Time Before: 0.00202 seconds
Time After: 0.00279 seconds
Time Taken: 0.00077 seconds
Time Before: 0.00290 seconds
Time After: 0.00331 seconds
Time Before: 0.00358 seconds
Time After: 0.00386 seconds
Time Before: 0.00457 seconds
Time After: 0.00723 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00391 seconds
Time After: 0.01062 seconds
Time Taken: 0.00670 seconds
Time Before: 0.01246 seconds
Time After: 0.01264 seconds
Time Before: 0.01507 seconds
Time After: 0.01629 seconds
Time Before: 0.01183 seconds
Time After: 0.01646 seconds
Time Taken: 0.00463 seconds
Time Before: 0.02156 seconds
Time After: 0.02170 seconds
Time Before: 0.02400 seconds
Time After: 0.02529 seconds
End call of global.php: 0.026969909667969
Time Before: 0.02926 seconds
Time After: 0.02942 seconds
Time Before: 0.03139 seconds
Time After: 0.03287 seconds
SET lastactivity = 1782948036, location = '/forums/private.php?do=newpm&explain=1&u=105258', badlocation = 1
Time Before: 0.04539 seconds
Time After: 0.04591 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
Page generated in 0.044487953186035 seconds with 9 queries, spending 0.0083687305450439 doing MySQL queries and 0.036119222640991 doing PHP things.
