Time Before: 0.02080 seconds
Time After: 0.02709 seconds
Time Taken: 0.00629 seconds
Time Before: 0.02722 seconds
Time After: 0.02762 seconds
Time Before: 0.02819 seconds
Time After: 0.02835 seconds
Time Before: 0.02928 seconds
Time After: 0.03154 seconds
Time Taken: 0.00226 seconds
Time Before: 0.02843 seconds
Time After: 0.03619 seconds
Time Taken: 0.00775 seconds
Time Before: 0.04687 seconds
Time After: 0.04727 seconds
Time Before: 0.04884 seconds
Time After: 0.05013 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04618 seconds
Time After: 0.05037 seconds
Time Taken: 0.00419 seconds
Memory After: 2,261.820 KB
Time Before: 0.07248 seconds
Time After: 0.07264 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.09219 seconds
Time After: 0.09370 seconds
Time Taken: 0.00151 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.10513 seconds
Time After: 0.10532 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.10805 seconds
Time After: 0.10956 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789016150, location = '/forums/private.php?do=newpm&explain=1&u=105264' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.12940 seconds
Time After: 0.13009 seconds
Time Taken: 0.00069 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
