Time Before: 0.00812 seconds
Time After: 0.00986 seconds
Time Taken: 0.00174 seconds
Time Before: 0.00996 seconds
Time After: 0.01059 seconds
Time Taken: 0.00063 seconds
Time Before: 0.01083 seconds
Time After: 0.01098 seconds
Time Before: 0.01228 seconds
Time After: 0.01438 seconds
Time Taken: 0.00210 seconds
Time Before: 0.01103 seconds
Time After: 0.01785 seconds
Time Taken: 0.00682 seconds
Time Before: 0.02133 seconds
Time After: 0.02152 seconds
Time Before: 0.02419 seconds
Time After: 0.02567 seconds
Time Before: 0.02077 seconds
Time After: 0.02587 seconds
Time Taken: 0.00510 seconds
Time Before: 0.03131 seconds
Time After: 0.03146 seconds
Time Before: 0.03501 seconds
Time After: 0.03629 seconds
End call of global.php: 0.039135932922363
Time Before: 0.04126 seconds
Time After: 0.04152 seconds
Time Before: 0.04388 seconds
Time After: 0.04538 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1788981656, location = '/forums/private.php?do=newpm&explain=1&u=105310', badlocation = 1
Time Before: 0.05934 seconds
Time After: 0.05961 seconds
Page generated in 0.05807900428772 seconds with 9 queries, spending 0.0080111026763916 doing MySQL queries and 0.050067901611328 doing PHP things.
