Time Before: 0.02249 seconds
Time After: 0.03264 seconds
Time Taken: 0.01015 seconds
Time Before: 0.03273 seconds
Time After: 0.03313 seconds
Time Before: 0.03337 seconds
Time After: 0.03349 seconds
Time Before: 0.03435 seconds
Time After: 0.03658 seconds
Time Taken: 0.00223 seconds
Time Before: 0.03356 seconds
Time After: 0.04079 seconds
Time Taken: 0.00724 seconds
Time Before: 0.04949 seconds
Time After: 0.04989 seconds
Time Before: 0.05259 seconds
Time After: 0.05382 seconds
Time Before: 0.04870 seconds
Time After: 0.05407 seconds
Time Taken: 0.00537 seconds
Time Before: 0.09190 seconds
Time After: 0.09205 seconds
Time Before: 0.10988 seconds
Time After: 0.11113 seconds
Time Before: 0.12081 seconds
Time After: 0.12099 seconds
Time Before: 0.12345 seconds
Time After: 0.12493 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=105325', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.14307 seconds
Time After: 0.14334 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
